I did mine without removing master cylinder, "only done by those that don't know what they are doing," or removing transmission. Read some of my posts and you will see that the drivers side can be done completely from underside. The trick is to lower the rear of the transmission, then you will have room to get to all the nuts and bolts with a socket and ratchet wrench from underside.
